Will the Telus Hwai USB stick work with public mobile?
Options
08-22-2019 05:59 AM - edited 01-05-2022 06:34 AM
I was just wondering, since public mobile is on the TELUS network, will their Hwai usb internet stick work with public mobile, and if so will it still work if you only have a 3G data plan?
-James
Labels:
Phones
1 REPLY 1
Options
08-22-2019 06:59 AM
Yes, I would think so.
I have used a Telus WiFi hub with PM many times. It is the Hauwai B882 hub. Works great. I can even make/receive cellular calls through the hub.
