07-31-2016 11:01 AM - edited 01-04-2022 02:54 PM
08-02-2016 01:21 PM
@dzideqk is the question is, will I get Public Mobile roaming service while outside of Canada? The answer, unfortunately, is no. You would need to purchase some sort of pre-paid service from a carrier in the EU, or a global roaming service such as iRoam (there are likely others but I can't think of them off the top of my head).
You would also have to verify that your phone is carrier-unlocked, and compatible with the frequencies in use by the carrier you wish to use while aboard.
Let us know if we can be of any fruther help!
08-01-2016 09:58 AM
Summarizing previous comments:
Phone: maybe
sim card: no
In order to work, a phone needs to:
a) connect to the towers (probably fine here, but check frequencies)
b) accept a sim card (phone will need to be unlocked to accept a European compatible sim)
c) have a sim card that works in europe (Public Mobile sims only work in Canada, so you will need a different one)
07-31-2016 11:22 AM
Right, just to add on to the above reply. Your phone also needs to be unlocked to work in Europe.
07-31-2016 11:04 AM
Your phone could work, but it depends on which phone you are using, and which carrier you will use in Europe.
But your PM SIM won't work outside of Canada.
