Will iPhone SE work with the Data at 3G speed?
wleung_2000
I an about to buy a phone and activate a second line for my family.
However, when I try to verify with the tool "To find out if you if your cellular phone is compatible with our network, click here." at the bottom of the page (https://www.publicmobile.ca/en/on/get-started), the combo boxes for Phone Brand and Model are both empty - totally not usable.
Could you confirm if iPhone SE will work on the $15 and $25 plan with Data at 3G speed?
And preferably file a report of the IT to fixed the compatibility check tool on the we
tweakthis
You are correct. The original SE was 206. Then a updated release in 2020. There is now a v3 for 2022.
wleung_2000
I thought the latest will be generation 3?  Nevertheless, I appreciate your confirmation for generation 1.
CountyDownIeUk
iPhone SE generation 1. Absolutely will work.
RossN
@wleung_2000 hi the tool has been broken for awhile they are aware, yes your iphone will work here you can check at https://willmyphonework.net/
