Wifi calling
TdogXR
Need help to upgrade so I can make calls over starlink
 self solution removed
TdogXR
Thanks I will look for another provider
SKSuh
You’ll have to “upgrade” to a different provider such as Telus, Koodo or the other two as Public Mobile seems unlikely to support WiFi Calling anytime soon
porcupine
Public Mobile doesn't support wifi calling
