SMS
Dee64
I’m not receiving verification codes on my phone, nor am I able to use wifi outside of my home. I have plenty of data left. Please advise.
1 REPLY 1
slusagm
Can you receive phone calls and call you make calls? And data work?
If just the 2FA SMS, click Didn't receive code or Resend Code and choose Send e-mail.
If email is not an option, then ask PM for help
 Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
