Wifi calling
Truck128
Does public have wifi calling
7 REPLIES 7
HI @Truck128 if Wifi calling is important, you have to move to Tier 2 or 1 provider, like Koodo or Telus.  Because of the cheaper price, no Tier 3 provider has Wifi calling
@softech- Ah. To specify the difference. Got it.
@Truck128  Fongo can receive text for free anyway.  So text in is not an advantage for TextNow
@softech wrote:
@Truck128 on top of what @CharlieWhisky suggested, TextNow is another VoIP you can try.  Sound quality is better than Fongo and it has text out for free.
....and text in.
CharlieWhisky
If you don’t mind using a different  phone number you can get a free number from Fongo (Canadian company) and use it for wifi calling.
dwh1
No, it does not.
