Wife
Timnoseworthy
Can I add my wife to my account?
Yes and no - you can get a plan for her and pay with the same method if you choose, but you have to do so with a different email and set everything up (self serve, autopay, etc) again for this account
@MrSpock wrote:
@Timnoseworthy No that really messes things up with their system
It does NOT mess up their system!!  Simply put you cannot do that!!!
do not use same email but you can use same credit card if you wish
You can use the same email if you use an alias to it.
Timnoseworthy
Thanks for the information
MrSpock
@Timnoseworthy No that really messes things up with their system, do not use same email but you can use same credit card if you wish
@Timnoseworthy   Add a second line?
For PM , there is no family account concept.  One email ties with one phone account.  So, you can activate your wife with another email address.
Make sure she uses your Friend referral code to activate and save $10 for activation (one time), and you will enjoy $1 (or 1 Public point) every 30 days
