10-03-2025 09:47 PM
I already did resetting network but still not working.
my phone is iPhone 11
10-03-2025 10:42 PM
It’s not on hold as well. Activated since 2020 Jan 17
10-03-2025 10:35 PM
I can use call and msg, just data not working.
Haven’t changed anything at all for long time
10-03-2025 10:23 PM
no voice calls as well? or just no data?
if no service at all, maybe did you reverse a PM or Telus or Koodo charge on your credit card?
Can you call 1-855-4PUBLIC from another phone, enter your phone number and check if your account is On Hold or active
10-03-2025 10:21 PM
Sim card didn’t work with other phone.
do I have to buy new one? Why it suddenly happened?
10-03-2025 10:14 PM
if you have another phone and using a physical sim, test the sim on another phone
if same or if you don't have another phone to test, ask PM support agent to refresh the account. Please submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
10-03-2025 10:09 PM
I’m an existing customer for long time and my phone is iPhone 11.
Already did the reset network setting, but still not working
10-03-2025 10:02 PM - edited 10-03-2025 10:03 PM
new or existing customer?
and what phone do you have?
if you have an iPhone, make sure you update your Carrier Profile
And if new customer, make sure you remove your old carrier sim card and disable old carrier eSIM, then Reset Network Settings again
