03-28-2022 11:02 PM - last edited on 03-29-2022 12:08 AM by computergeek541
03-31-2022 08:54 PM
@RebeccaWitham wrote:I have data left but today it said the provider has switched it off. Why??
@RebeccaWitham some possible fixes / culprits:
1. Restart your phone
2. Get a SIM replacement (but first, try the SIM into another device to see if issues persist, and first wait it out a bit, if this is network related)
3. Phone Lost or Blacklisted. Check if your phone is blacklisted here: https://www.devicecheck.ca/check-status-device-canada/
4. Non-Payment of Account (does your account show ACTIVE status: check self serve or call 611 from your device)
5. Temporary interruption in your area
03-29-2022 08:43 PM
Thanks for your answer on this. I haven't received the notification since turning my phone off and back on again, so that seemed to work.
03-29-2022 02:06 AM
It's intermittent radio problems. If the tower is not transmitting the LTE signal properly then the phone sees that LTE is no longer there and gives that internal phone notification. It has happened to me once before. It happened to me twice earlier today.
You could turn airplane mode on and off. Or do a restart. To let it reconnect if it can.
03-29-2022 01:29 AM
That's right. I have to use wifi. What do you mean my "date is turned off?"
03-29-2022 12:07 AM - edited 03-29-2022 12:09 AM
@RebeccaWitham @Ferret It could be a glitch from PM. Maybe I'd suggest raising a ticket to PM support to see if there's a problem on their backend?
here's the link:
03-29-2022 12:02 AM
And your date is turned off and you can't access internet without WiFi?
03-28-2022 11:50 PM
I'm on a 5GB plan, $40 a month. According to my data usage I have just under half left.
03-28-2022 11:49 PM
An alert/notification appears on my phone where my other usual notifications are.
03-28-2022 11:47 PM
Yep, exactly the same as me!!
03-28-2022 11:40 PM
Is this a text? Am email?
03-28-2022 11:39 PM
Just happened again! It keeps saying "Data temporarily turned off by your operator".
Why??
03-28-2022 11:33 PM
I'm having the same problem with a message saying the provider has switched off data. I still have kits of data left for this month and so don't know why it would be switched off intermittently by Public Mobile.
03-28-2022 11:04 PM - edited 03-28-2022 11:04 PM
Have you checked your data usage in your PM account or on your phone? What plan are you on?
