Why can't I send photo text messages?
ShadowCK
I can't send photo text messages. I called Public mobile and they had me download GOSMSPro or something like that... it was fine for a while...then even that app made my regular texts screw up. I deleted that app.  I never was notified about messages at all. I just want to be able to send the messages normally as I was able to before. I have unlimited text and picture messaging.
If anyone can help me, I'd appreciate it.
Thanks
15 REPLIES 15
erikdaviking
OK, thanks.
@erikdaviking wrote:
Hi,
I can send photo text messages when I have data turned on, but when I turn data off (and am connected to wi-fi) the photo messages do not send.
Cheers, Eric
@erikdaviking  Even though MMS does not use data you need to enable data on your phone for MMS to work.
@erikdavikingBecause photo messages ie MMS requires data.
erikdaviking
Hi,
Cheers, Eric
Hi @Lesliegallant30 You would want to start a new thread.. what kind of help are you looking for?
Lesliegallant30
I also need help
Can you post instructions for iphone?
@erikdaviking  What model of iPhone do you have?
sunflowershine
@ShadowCK As long as you have wifi or data on, you are able to receive or send MMS.
This is the reference for all things Apple and data. MMS or "photo text messages" need data mode to be on and proper APN settings.
erikdaviking
Deebaby7474
I had to factory set my phone then put apn its all working now
chukdefatey
^Both of you need someone who is knowledgeable to look into this issue because this issue is not on PublicMobile end.
Deebaby7474
I'm having same problem if u figure it out please let me no
ShadowCK
Hello. I did all that. It's all set.... I don't know what else to do. My phone is a Samsung (Android) model SGH-T599 Android version 4.1.2
Cyber
@ShadowCK,
You need to activate your Mobile Data and configure your APN to be able to send pictures (MMS) and use DATA.
Do you have an iPhone or Android phone ?
Android APN step-by-step configuration :
Lithium-OrangeBullet-Jan23-00.jpgStep 1
Android
Settings > More / More Networks / Wireless & Networks > Mobile Networks > Access Point Names > New APN setting (or a plus sign)
Click here for Android APN Screen Shot
Lithium-OrangeBullet-Jan23-00.jpgStep 2
You will need to input the following information :
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN type: default,supl,mms,dun
Lithium-OrangeBullet-Jan23-00.jpgStep 3
Select Save/Done. Select Public Mobile to connect to the Public Mobile network.
