Why are there two $18/m subscriptions
Cc30
Does anyone know if you choose to change on renewal they will honor plan if it expire by then?
The new 18$/1gb plan is says to expire tmr (26 dec) but my renewal in in jan
Frank52
Hello @Cc30,
You might be able to see two $18 plans because you were previously on the $15/month plan that has been removed and replaced with the new $18 plan. Public Mobile is giving you the option to remain on your old plan at the new rate of $18/month or you can opt for a slightly better plan that offers 1 gig of internet at the exact same price. The only condition is that you need to choose to switch into the new $18 plan yourself. As others have pointed out though, you should consider switching the plan on your next renewal date to avoid getting double charged for the current billing cycle.
@Cc30
It will automatically renew if you are on AutoPay (Subscribe) button is enabled.
@Cc30
You can lock in the plan by using Change on Renewal option to schedule the plan change on renewal day.  Yes, with this option, PM will honour the deal
