Where's the US Roaming Talk Only Plan for $8?
SomeDude
I need to purchase the US roaming talk only add-on for $8 but I no longer see it on the self-serve page.  I've purchased it twice before in December.  What happened to it?
dna2016
@SomeDude, the Add-on is still on the main website page so it's definitely still available.  If you don;t have a talk option on your base plan then it won;t be an option for you, however you mentioned you applied it earlier so I assume you do have a talk plan.
I noticed on my account page it is populating an error message when going to plan details and such, and this error was happening infrequently yesterday as well.  I think there's just a system glitch at the moment.  I;d say give it an hour or so and check back into your account again.  This was happening yesterday as well.
SomeDude
@Carld123 wrote:
@SomeDude
Its still there but in the talk section for some reasonScreenshot_2018-12-28-09-28-28.png
On my screen the $8 talk plan is missing, and this affects the person I'm with as well.
My original assumption was that they eliminated the plan, but now I think the two of us are affected by some sort of software bug with the public mobile site.  Perhaps the bug has something to do with previously purchasing the $8 plan twice?
Due to time constraints (I need to be reachable), I bought the $15 talk and text plan already.
mimmo
Could it be that, it might take a little bit for it to reset itself. You should be able to call 611 or 18554public (I think that was the number) and purchase add-ons that way. That system might be different than the online system.
Carld123
@SomeDude wrote:
My add-on expired at midnight.  It's no longer active.
@SomeDude
Its still there but in the talk section for some reason....
.edit...actually its not a roaming bundle so its in the correct spot...Screenshot_2018-12-28-09-28-28.png
SomeDude
ShawnC13
Is the addon currently active on your phone?  If it is it won't show up as available until the current one expires.
