Where is my data going.
drtglynch
I have been a public mobile user for a little over a year, with a 90 day, 6GB data plan. Over my first three terms i barely reached 50% usage of my alotted data. In Jan '19 after my 3 month reset i noticed that my full 6 GB was used up  within a couple of weeks. My habits did not change and i cannot account for this usage. I decided to wait it out until my next reset in Apr but got tired of having to look for wifi passwords wherever i went so I purchased a 200 MB add-on ton Mar 11 to get me through on the very limited times i was not connected to wifi. I monitored my usage closely. Today... Mar 16, my data was again cut off. I DID NOT use 200mg of data in the last few days. In fact, the data useage link on the website shows only  a cummulative total 32 MB used since Mar 11.  What gives? I will be switching to another carrier if this cannot be reasonably explained. Can you help me? Thanks, Terry
7 REPLIES 7
@drtglynch, check your internal data monitor settings.  Have you set a limit on it that maybe crossing plan renewal cycles?  Data usage doesn’t reset monthly at Public Mobile, so if you’ve set a monthly limit, it maybe out of sync.
In the Google Playstore, I recommend the Data Witness PM app.  You can set for 30 or 90 day cycles.  This app isn’t available for iOS.  I think there is one in the iOS App Store call Data Monitor, and many others that do the same.
Psygineer
@drtglynch wrote:
Even If there were apps updating behind the scenes i still cannot understand why the public mobile data usage link does not reflect this .  It says only a total of 32 Mb has been used since i purchased the 200MB addon.  My iphone settings  are configured to not update apps through cellular data. I am downloading a data monitor app now .
Mine are configured the way. I have told it not to use data period. I would still end the 30 days with between 10-25 MB used.
PMOttawa
Go to Settings --> data usage --> more
and select restrict background data and restricted network.
and keep monitoring let us know if that make a difference for you.
drtglynch
Psygineer
Your data goes to the same place my data goes. I have not enabled data for over a month, but I still have some usuage on it. There are apps are your phone that ignore disabled data and use it anyway. The phone itself likely performed an update.
NuYearNuMobile
Phone Home Screen> Settings>Data Usage.
You can also check past usage history.
Check & u will find some answers.
Something similar should be there if you use iOS or newer Android versions.
I know where you're coming from & its frustrating.
But don't panic as you should be able to find the app that gulped your data.
Alex888
@drtglynchCheck your setting and make sure your phone and apps are not trying to update or install using data. Try installing a data monitoring app that records the usage of each app seperatly.
