08-28-2018 01:23 PM - edited 01-05-2022 12:42 AM
I have 2 public mobile numbers, but I tried to port one of them away to another provider. It got rejected for being an invalid account number. The account number I used to port out was the account number listed in the top-right area of the public mobile self serve, my account website. It was a number like 1000000####### (where the #'s are numbers of my account). Is this not the correct account number, and do I need to contact a MOD prior to porting out?
03-05-2019 03:25 PM - edited 03-05-2019 03:30 PM
@ammy1 wrote:Where i can find my account number
my number is xxxxxxxxxxxx
Please do not include pesonal info in your post, you should edit your post and remove your number (select 3 dots). This is a public forum. You can find you account number when you login into your account. Just select the "My Account" top right of this page. Once you login your account information will be displayed on the landing page.
03-05-2019
03:22 PM
03-05-2019
04:39 PM
computergeek541
edited by computergeek541: removed phone number
08-29-2018 03:14 AM - edited 08-29-2018 03:14 AM
Thanked you computergeek 🙂
08-28-2018 09:29 PM
@cal800 wrote:Yeah those account numbers with all those 0's are hard to read.
And I couldn't copy and paste as it was not regular text.
It can be copy and pasted from your Public Mobile activation/welcome e-mail message. They put it next to your e-mail address instead of your name.
From there, you can paste it into an online activation site, or if you are porting out your Public Mobile phone number at a store, you can print it out in an enlarged font and bring it with you.
08-28-2018 08:58 PM
08-28-2018 02:16 PM
Yeah, when I told them the number I remember saying my account number is "one and then six zero's in a row, as in one million,..." and then the next 7 digits.
08-28-2018 02:13 PM
It is a bunch of 0's. I've got a vision issue, so I counted a few times.
Try it again - advise them there are 6 '0's, and 7 digits following the 0's.
08-28-2018 02:06 PM
yes, my name and address is all correct. I have quintuple checked everything. My main question was if this 14 digit account number with the 1 and a bunch of 0's was the real account number. I'm guessing the new provider agent took down the wrong number.
08-28-2018 02:04 PM
All you should need is your account number, and your name, and your phone number.
Is your name currently registered in your Public Mobile account?
Other than that, I have no suggestions.
08-28-2018 02:03 PM
I have 1,6 0's in a row and then 7 digits. 14 digits in total.
08-28-2018 02:01 PM
The account number is 14 digits long, starting with a 1, then I have 7 '0s', then 6 numbers.
You may have 6 '0's then 7 numbers? Double check.
08-28-2018 01:58 PM
I can still make calls with this line - active
08-28-2018 01:58 PM
It's active, as in you can still use your service? Or is it waiting for you to pay to use it?
08-28-2018 01:38 PM - edited 08-28-2018 01:39 PM
Yes it's still active. So I don't need to contact a MOD first? Just scratching my head as that's the account number I used. I did tell that account number over the phone to the rep of the new mobile provider. Maybe they entered it wrong? I just wanted to verify this was the correct account number before trying it again.
08-28-2018 01:36 PM
That should be the account number.
Is your account still active?
If yes, try the port out again.
