When will I get $10 for using referral code?
Dima91
I signed up and used a referral code. It said that I should get a $10 bill credit. I already paid full price for the first month when I signed up. So will $10 credit get applied to next month bill?
Andy85
@kb_mv wrote:
@Andy85 wrote:
Additionally, you might qualify for refer-a-friend monthly rewards if you are still on the old legacy rewards system! So double-win!
@Andy85 Not a double win. The person that uses the referral code gets the $10 credit. The person that provided their code for the OP to use gets the refer a friend reward/credit.
Oh yes. Thank you for correcting me! Yes, I had read the OP too quickly. The person referring is only entitled to the $1 monthly rewards (assuming they are on the legacy rewards system)
Andy85
Hi @Dima91 ,
The system normally takes 3 days for your $10 referral credit to appear on your account. I would check back then. Additionally, you might qualify for refer-a-friend monthly rewards if you are still on the old legacy rewards system! So double-win!
hi @Dima91 within 72 hours after activation.  You will see it in Available Funds and you can use it for addon purchase
.... or add-ons, or a sim.
kb_mv
@Dima91 You should see it credited to your account within 72 hours. It will be used for your next renewal.
