WhatsApp hacked
TAlam1977
What should I have to do now my WhatsApp is hecked and I want retrieve it need help
sheytoon
If your phone number is still in your possession, just log in again to get access back.
Then make sure you change your voicemail PIN. Some hackers are asking for the WhatsApp 2FA code to be delivered via phone call overnight while you're asleep, which will create a voicemail with an automated voice that speaks the WhatsApp 2FA code. If they can guess your voicemail PIN they will get the WhatsApp 2FA code.
slusagm
For PM, make sure you change the My Account login password
For yourself, change password for all your emails and bank
For WhatsApp, contact their support
hairbag1
@TAlam1977
so what makes you think it's hacked ? You could delete the app form your cell...then get another.
