11-05-2022
01:35 AM
11-05-2022
10:11 AM
Dunkman
What happened one minute I,have voicemail then the next its gone! My signal strength is terrible what has happened?
11-05-2022 10:12 AM
Are you still having issues? Might be a temporary outage in your area.
A few basic troubleshooting advice:
Try to reboot phone.
Try your SIM card in anther phone to see whether same issue
11-05-2022 01:48 AM
Can you switch to 3G-only or UMTS or WCDMA.
What do you mean voicemail is gone? Can you get in to voicemail? Can voicemails be left?
