06-29-2019 09:21 PM - edited 01-05-2022 05:39 AM
Hi,
I am wondering if you get lower data speed on PM after data is finished or not? This is for CAD 25 plan.
06-29-2019 09:23 PM
@Somojana1 wrote:Hi,
No, once your data is used up you no longer have use of any data. You can purchase a data add-on, use only wifi, renew your plan early (needs moderator assistance) and finally you can wait until your plan renews automatically
06-29-2019 09:22 PM - edited 06-29-2019 09:23 PM
@Somojana1 no when you use it all for the cycle it's done until next cycle or you buy an add on
