Webpage says 4G+2G bonus data on 3G network for $50 but I wasn't able to select it?
04-06-2018 11:34 PM - edited 01-04-2022 04:03 PM
04-07-2018 11:53 AM
Hello Raypro,
Thank you for reaching out to us.
I am sorry to hear that you are unable to select the $50 plan.
In order to better assist you, please send us a private message.
I am waiting for your response.
Cheers
Abdoulaye
04-07-2018 12:07 AM
@Raypro wrote:I sent the mod team a private message to see if I can have it switched. It wasn't available as a pre made plan when I signed up. Even when I tried to make the plan, It was over $50. I'm sure they'll be able to hook me up.
Thanks
Thanks
When I go to plan builder I can put the plan together for $52 which is correct with autpay reward it is $50. In the pre made plan it says autopay reward included that is why it shows $50
04-06-2018 11:56 PM
Thanks
04-06-2018 11:52 PM
@Raypro, you are the second person I have seen that has had this issue. You will need to private message the mods and see if they can fix this for you. Unfortunately they are gone for the day but will be back tomorrow.
- PM Phone Number
- 4 digit PIN (if you don't remember this then they will need at least 3 of the following to verify your identity)
- account number
- date of birth
- complete address listed on account with postal code
- email address on account
- most commonly called numbers
- alternate number listed on the account
- last payment date and amount
- last 4 digits of the credit card
- Detailed explanation
04-06-2018 11:50 PM - edited 04-06-2018 11:51 PM
@Raypro You can go to Build Your own plan and select the plan manually. This plan is also one of the choice in the ready made plan. https://www.publicmobile.ca/en/bc/plans/50for6GB-3Gspeed
If you already activated with another plan, you will need to send a private message to the Moderator_Team with your account info so they can make changes to your plan.
More info on contacting mods:
- Follow the directions in this post: http://productioncommunity.publicmobile.ca/t5/Getting-Started/Private-Messages-viewing-and-creating/...
- Once the Community Moderator has responded to your private message, they will provide you with a secure link so they can authenticate your account information
- In order to validate your account information, you will be asked for 1) Your account number and 2) Your PIN number
Monday - Friday 9AM (EDT) - 9PM (EDT) Saturday - Sunday 9AM (EDT) - 7:00PM (EDT)
