Vpn
Jimmyjongaj
I just changed my plan yesterday only to find my vpn doesn’t work anymore, I went from Canada only to a plan that was Canada US and Mexico, would that be the reason why it stopped working?
2 REPLIES 2
hi @Jimmyjongaj
your data not work at all or just not with VPN enabled?
and you were using 3rd party VPN? which one you using?  try uninstall and reinstall the VPN app
@Jimmyjongaj
PM doesn’t block VPN. It would be the VPN app settings on your phone.
i don’t have any issue when I use the VPN on my iPhone.
