Vouchers
Zx1
Hi I can’t seem to add my voucher numbers, says can’t add....?
40 REPLIES 40
RossN
if you just bought them you may have to wait till tommorow to input them
@Zx1 wrote:
Did that says not valid I bought 2 $5 and 1 $20
Can you get into the self-serve?
611 should work up until account deactivation which happens 90 days after suspension.
Zx1
@Zx1 wrote:
611 no longer works
Let alone expired...is it past 90 days? 611 or *611 should both work to get to the same place.
brennanleblanc_
@Zx1 wrote:
611 no longer works
Did you make sure to put a * before the 611?
RossN
did your plan expire?
Zx1
611 no longer works
Zx1
Ok
Try in the 611 service. 12 digits only.
Edit: ninja'd by RossN 🙂
RossN
try *611 on your phone
