Volte
john2112
How do I check if my new phone is supported by volte, or whatever
@Alveeto
just ignore that comment, the IMEI checker is accurate
just the $5 charge is a bit confusing at this point.  Some has a VoLTE enabled device but still got the text
Alveeto
So what's the 100% accurate way to know if I'm going to get charged $5?
slusagm
What phone is that?
If it is a Canadian model, it should work
But if course,  since you have the phone with you, use the IMEI checker at the bottom of the page to confirm
https://www.publicmobile.ca/en/get-help/articles/volte
Chalupa_Batman
Just know, that the Public Mobile's VoLTE checker as a guide only, as results are not always 100% accurate.
umnikke8
If you have the phone, use the checker on the help page https://publicmobile.ca/en/get-help/articles/volte
