10-22-2019 01:17 AM - edited 01-05-2022 07:40 AM
How to o access my cellular voicemail from an old landline phone? Thanks
Joining Public
10-22-2019 09:17 AM
You can access your voicemail from a landline or any other phone line, by dialing your 10-digit phone number, selecting ‘Send’ or ‘Call’ and then pressing ‘*’ to skip the system greeting.
10-22-2019 09:14 AM - edited 10-22-2019 09:15 AM
@triciad If you are on the $10 limited calling plan then just dial area code + 580-4001. If it doesn't work because of muttiple area codes in your area try rotating the area code until you get through.
10-22-2019 01:58 AM - edited 10-22-2019 01:59 AM
@geopublic wrote:
@triciad wrote:How to o access my cellular voicemail from an old landline phone? Thanks
@triciad Dial area code + 580-4001 and just follow the prompts to access your voicemail.
That won't work if that area code doesn't have voicemail number. Not every area code + 580-4001 is a vm number. When calling from a landline to check, it's easier to call your own number.
10-22-2019 01:49 AM
10-22-2019 01:25 AM
@triciadDial your cell phone number from the landline, once your voicemail messages starts press *
