02-22-2017 04:42 PM - edited 01-05-2022 01:45 AM
I've set up my phone but I'm not able to receive calls...they go to my Rogers voicemail. I've set up my Public voicemail as well but still can't receive calls.
02-23-2017 12:01 PM
@kellyrae1 are calls coming through now? Please give us a brief update when you have a moment, so we know if you need further assistance.
02-22-2017 10:57 PM
As suggested above, wait for the text message informing you of a successful port.
If you are still having issues tomorrow, send a message to a MOD
02-22-2017 04:58 PM
Seems like porting issue. Wait couple of hours and try rebooting your phone. If services stop working with your rogers sim, then your porting has been processed. If you mistakenly provided wrong info, it might get stuck and you will have to get in touch with mod to get it solved.
02-22-2017 04:45 PM
IM guessing you ported your number over? if so did you receive a text saying the port was done?
