Voicemail
DebHep
I am unable to check my voicemails.  I can call out and receive calls fine but when I call to check voice mail it says it cannot complete my call.  I have voicemails sitting there that I can’t check.
@DebHep
try reboot the phone and try again
Also, you can call from yourself  from a landline or any other phone line, press  ‘*’ to skip the system greeting.
DebHep
It doesn’t show a number, just says error making ca
JRod
Dialing your own number will also take you to voicemail. Will your call complete if you try that?
DebHep
Yes I am, I don’t know any other way to access my voicemail?
dust2dust
Try dialing 1-778-580-4001. What shows as being dialed when you press and hold the 1 key?
JRod
@DebHep
Are you hitting a voice mail button to automatically dial your voice mail? What happens if you try to dial your own number?
