Voicemail notification on Android
Ken2000
Hi,
I am not getting any Voicemail notification.  If I go into my Voicemail, the messages are there.  Voicemail notification is enabled for all hours, through Text messages, but I am not getting any.
pmbc
@Ken2000 You might want to check your notifications settings and just make sure there is nothing that is muting or blocking VM notifications.  I'm not an android user so I can just offer some general suggestions unfortunately.  Hopefully someone more familiar with Android can chime in too! 🙂
Ken2000
I am on a Galaxy and it is locked to Enabled.
pmbc
In Android, have you tried to turn voicemail notification off and back on again to see if that will trigger it?
Ken2000
Done that many times already.
pmbc
@Ken2000  Might want to try the simplest first step and restart the phone if you haven't done that already.
