08-28-2018 06:35 PM - edited 01-05-2022 12:42 AM
I was just wondering about the details of voicemail that Public Mobile offers.
1. How many messages can you save.
2. What is the maximum length of time that the messages can be.
3. How long are voicemails saved in the message box.
4. Does Public Mobile have a visual voicemail option?
Joining Public
02-13-2020 04:00 PM
You can have a maximum of 10 voicemail messages. If you want to keep a message for an extended period of time you will have to re-save it frequently.
Once messages have almost reached their expiry date, you will receive a deletion warning. You will be asked to delete or re-save the message. If you don't re-save the message, the system deletes it on the expiry day.
10 days
No
08-28-2018 06:51 PM
@thirstyturtle18 I don't know exactly how many voicemail or length, but some other info can be found here: https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/How-To-Use-Your-Phone-and-Plan-Feature...
Regarding the visual voicemail, PM does not currently offer this feature.
