04-25-2019 02:00 PM - edited 01-05-2022 04:36 AM
Hello does anyone have same problem as i do my voicemail messages are always
delayed by 3 hours......how to fix this or how to contact mod. to fix this issue...
...................................Regards..................................
12-12-2019 05:38 PM
@irishman4 wrote:Sorry .....for the Delay.....for my case it was resolved ..the very next month...all came back to normal.....contacted the Moderator Team.....i guessed it was fixed by a very good team..
so my advice ....to contact Moderator team...pretty sure they will fix it for You....Regards...
Kirk? Is that you? 🙂
And I thought I made liberal use of ...'s
12-12-2019 05:36 PM
12-01-2019 06:40 PM
What is the solution? is it posted somewhere. I've been having this issue for months now, but delays can be for days. I can check voicemail with no messages on the day/time i actually get messages and will not be notified. Seems like the messages randomly become available days later (ie. messages accumulate for days). Can anyone help?
04-25-2019 02:50 PM
@irishman4 wrote:Pizzaeh To make sure we understand each other,.....never touched anything....
you just sent me text messages ...received 'em ...in seconds.....
text is Ok.....but NOTIFICATIONS from Voicemail.....3 hours..!!!!
so Contacted MOD. Team... thank you.....will accept this as a Solution for NOW..
........................................Regards.......
P.S.: if ain't broke don't touch it...............
@irishman4 , just to be clear, these posts and my replies are not text messages. These are posts within the online forums, that use data.
Yes, if it ain't broke....but it is broken, since the last major update. It's not unheard of for a software update to break things.
Cheers mate.
04-25-2019 02:48 PM
04-25-2019 02:45 PM
04-25-2019 02:42 PM
@irishman4 once this is resolved, please post the solution in this thread. It will help future subscribers who search for the same issue. Thanks.
04-25-2019 02:37 PM
@irishman4 wrote:
Pizzaeh Read this article .thank you ..but it didn't help...& as already mentioned as an old tech ..i've learned never to touch anything went everything is working...fine .....so i checked all settings ...etc..automatic network..it's ON..etc....everything is Ok.........it just started going goofy.....after last major update wehad couples weeks ago.........
Generally yes, but it's not working fine since the last major update. Even though the network settings haven't been manually touched, something could have been broken by the last major update, is all I'm saying.
To send a private message to the moderators click here. Response time is between 1 to 48 hours or longer; there have been some issues lately that have extended the response times. Hopefully they can resolve your issue.
Moderator hours:
Weekdays 8am to 12am (eastern time)
Weekends 8am to 10pm (eastern time)
04-25-2019 02:33 PM
04-25-2019 02:29 PM
04-25-2019 02:27 PM
04-25-2019 02:24 PM - edited 04-25-2019 02:26 PM
@irishman4 wrote:Pizzaeh No Since they did last update ....been working this lway never touched no settings......old folks like ... still using old proverb ...if ain't broke don't touch it...
which i never did....it just changed working this way since last ...Major update....!!!!
Since last major iOS update? That certainly could have affected it, which may require a network reset on the phone. This is the solution people have used for this problem.
Just to be clear, a network reset is not the same as a factory reset. Nothing "should" be lost, by resetting the network settings on the phone. However, it's always prudent to backup the phone regularly.
04-25-2019 02:24 PM
I like your proverb....and it was the same for me..before public mobile. ![]()
04-25-2019 02:21 PM
04-25-2019 02:20 PM
@irishman4 wrote:Hello does anyone have same problem as i do my voicemail messages are always
Do you mean the notification of the existence of a message? Or the message being there at all for 3 hours even if you check for it after missing a call?
04-25-2019 02:19 PM
@irishman4 wrote:
Pizzaeh Hi....A good ol' apple Iphone5...
Everything I'm reading about this problem in general (with any carrier), has to do with resetting the network settings on the phone. The following page (link below) is for Koodo, but I've read this for Verizon, att, etc. Have a read through and see if it helps.
Delayed voicemail notifications
04-25-2019 02:18 PM
In your settings...phone...calls...anything set up to delay the messages?
04-25-2019 02:15 PM
04-25-2019 02:13 PM
What phone do you have?
04-25-2019 02:01 PM
Strange...something in your voicemail settings???? It's not the case for my account.
