Voice plan change
Stevie6
Hi!
could somebody explain why since the last time the voice plans were updated there is this interesting thing: the province wide plans and the Canada wide plans are both the same price...is there a difference at all in those 2 plan options?
@Stevie6
You should note that pm has eliminated the $15 canada-wide calling plan and replaced it with the $15 province-wide calling only plan so if you have that plan you are grandfathered in until you change it.
Stevie6
That makes sense. Thanks
Dunkman
@Stevie6
Public mobile is increasing the Canada wide calling plans an extra $5/month.  But, as a temporary "sale", Public mobile is offering the Canada wide calling plans a $5 per month discount.  Not sure when the "sale" will be over.
Otherwise, the plans are the same except province wide versus Canada wide calling.  Same price for now until the sale is over.  Then the Canada wide calling plans will be $5 per month more expensive than the comparable province wide calling plans.
