Voice mail
BrianRobertson
How does one listen or go to voice mail, is the a number or task one needs to use?
BrianRobertson
Thank you so much it helped me a lot.
hi @BrianRobertson
these are the voice mail Access number.
https://www.google.com/url?sa=t&source=web&rct=j&opi=89978449&url=https://productioncommunity.public...
you can go to the phone app, click settings, and add the voicemail number there
slusagm
press ans hold 1 and it should work
If it does not call VM, click Reset Network Settings and it should program the Long Press 1 for calling VM
