03-12-2024
07:41 PM
03-13-2024
12:45 AM
computergeek541
Does anyone know how to stop scammer from leaving message on my voicemail. I blocked the number but it still comes through to voicemail.
Service
03-12-2024 08:08 PM
Thanks
03-12-2024 08:05 PM
Agree @Brianna182
Great point.
03-12-2024 08:02 PM
As someone who works in healthcare administration, I recommend against doing something like this because many places like hospitals don't have the capacity or even the ability to text you and if they can't leave you a voicemail may end up cancelling appointments
03-12-2024 07:52 PM
@Pete63 - Yes, it does, don't type in my typo number (507-580-4001) type in 587-580-4001.
03-12-2024 07:50 PM
Thank you that sounds like an option
03-12-2024 07:49 PM
Thank you
03-12-2024 07:48 PM - edited 03-12-2024 07:52 PM
@Pete63 - Turn on Extended Absence. That will not allow phone calls to go through to voicemail, but with a message. Tell them that to text me if you want to get ahold of me. How to do it:
- Call voicemail (587-580-4001) type in your PIN if you have one enabled for your voicemail even when calling from your phone.
- Press 3 to manage greetings
- Press 4 to enter the extended absence menu
- Record your message
- When done recording the message, press 5 to disable callers from leaving a message to your voicemail
If you were asking if you can block specific ones from making a voicemail - you cannot.
03-12-2024 07:42 PM
There's NO way @Pete63
An option is to change your number, which users can do up to 4 times per cycle.
Recommend just letting it go to voicemail and not answering.
