12-29-2021 11:07 AM - edited 01-04-2022 04:45 AM
I'm a new subscriber...for some reason I can't access my voicemail. Any help is appreciated.
Thanks in advance.
12-29-2021 11:49 AM
Glad to hear the problem's solved!
12-29-2021 11:20 AM
@ih82cuw8 : You can also dial any of the access numbers...but as mentioned, the main problem might be that pressing and holding the 1 key isn't set up. That's the standard method.
12-29-2021 11:15 AM
Thanks that worked!
12-29-2021 11:08 AM - edited 12-29-2021 11:09 AM
What happens when you call your own number from your own phone?
It's possible that the "1" button will need to programmed to access voicemail. What type of device are you on?
