Visiting Bermuda
amypot
Does anyone know if the international calling works in Bermuda?
JL9
Much more reliable and cost effective to go with either. A local prepaid sim. A VoIP app or a calling card option
fujiyama
No, Public mobile does not work outside Canada. (Roaming only works in USA if you buy an add-on.)
It's always cheaper to buy a local SIM when traveling 🙂
dust2dust
Nothing from here will work when in Bermuda. Nor is Bermuda included in the calling from here. You would need to find a local sim or use a voip app.
