Viewing data usage
DDM69
I'm having trouble looking at data totals per specific month.  I can see my usage history for this month but can't seem to get a total per specific billing cycle.  Is there any way to do this?
I could use an app I suppose but I'd rather see it on the Public Mobile website when I log in.
Thanks
9 REPLIES 9
@asifaftab wrote:
You do not need any app, your smartphone already have this feature. Follow this picture, hope that will help
That's a good starting point. Unfortunately, it will never be entirely accurate because Public Mobile's plans are either 10, 30, or 90 days in length.
asifaftab
my data counter on my phone claims I've already used 2.87gb and public's website says 2.1gb. I prefer public's counter to my phones 😜
Triguy
Your phone should also have built in data tracker app, it probably won't be accurate as public mobile is 30/90 days and your phone is monthly but you can adjust it to your renewal day each period or download an app called data witness
https://play.google.com/store/apps/details?id=com.iwik.datawitnesspm&hl=en_CA
Staliger
@DDM69 Yes, it is. You also can go to self-service account - Plan and Addons - Usage History. There you can select either 7 last days or specific term. It shows everything - text usage, calls, and data.
DDM69
The term is my billing cycle?
JoyLuck
gblackma
@DDM69 sorry, no, but if you sort it for 30 days by data. You get a pretty good idea how much you used.  Thanks. Stay safe.
@DDM69 wrote:
I'm having trouble looking at data totals per month.  I can see my usage history but can't seem to find a total.  Is there any way to do this?
Thanks
You can sort by the top headings. The overview page counter has your total for the term (not month).
