a week ago
I just landed in the USA (Drove, not flew) and connected to Verizon and got to use SMS, calls and data.
T-Mobile and AT&T works.
Wednesday
@hTideGnow - Thanks!
a week ago
HI @fixin1
thanks the details test for us. Happy that finally we have one more choices. Yes, the AT&T 5G seems not as reliable, I guess it is good Verizon has a solid 5G
enjoy your trip.
a week ago - last edited a week ago
@hTideGnow - It is complicated. It has a higher ping rate (500ms) compared to AT&T and T-Mobile (100-200ms) while all achieve the 250mbps rated speeds. So Verizon just feels a little bit slower despite that the speed is good.
Larger Municipalities (Like Spokane, Sandpoint, Bonners Ferry) are more reliable than in more rural zones, the other two (T-Mobile and AT&T) both work good in rural and urban landscapes.
Oh and 5G support on Verizon is way better than Verizon LTE, slow on LTE, about 250 mbps on 5G
a week ago
so Verizon is really slow? T-Mobile and ATT has better speed??
@hTideGnow - Northern Idaho. Loaded up the website to post. Reliability issues to get things to load. Similar to Rogers EXT network with PM it is super slow (less than 5mbps)
a week ago
thanks for the update, so where US you are in??
