Verification code to the wrong phone number
Ace001
Hi, when i tried to login, it asks to send a verification code. However, the phone number isn't my phone number. Not sure how I can fix this as it isn't in my profile. Thanks in advance.
2 REPLIES 2
Phil_Adelphus
@Ace001   If you are able to log in by getting the code via email, go to your Eversafe profile within your PM account and make sure the correct phone number is entered there.
@Ace001
You can click on Resend Code/Didn’t Receive Code and have it sent by email.
You might have to try several times if it didn’t work the first time.
Then go to the Profile section and change if it is wrong.
