Verification code inaccessible
paulbmckenzie
I purchased an eSIM and couldn’t get it to work on my iPhone. Then I purchased a physical sim and now I can’t get it to work because I can’t get the verification code @CS_Agent
2 REPLIES 2
hi @paulbmckenzie
tagging CS agent won't help, they don't usually monitor the Community
To change from eSIM to physical sim, you have to ask them to update the sim card number on the system.
 you can submit  ticket by direct message:
slusagm
you need PM to update the sim card number for you
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
