Validation Failed.
Priority
Hey for some reason Credit Cards aren't being accepted during Activation today.
I've tried 3 cards and it's not Accepting any to Activate a $50 • 100GB Plan.
App, Website, Cache Cleared, still not working.
Can we please get this fixed. Screenshot_20231220_135510_Public Mobile.jpg@J_PM
dani-danneyland
Have you moved recently? You'll notice that the form asks for a postal code. The postal code that you enter should match whatever address you have on file with the bank/company that manages your credit card. Make sure your address is correct with those providers, and then try again. Make sure to remove spaces in the credit card, and ensure the postal code is being entered correctly too (if it wants a space or not).
Otherwise, you may want to contact a Public Mobile agent for help activating. You can contact them at: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Hi @Priority
tried different credit cards?? Visa and MC same result?
TheSterlinger
Sometimes the system rejects the payment methods. Have you tried seeing if a CS agent could help? Sometimes they are able to get the payment through. https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
If you already did then try waiting a bit then trying again if still nothing then you might be out of luck.
