V15 international phone compatibiliy
chatrine
HI There,
I tried using the link for the compatibility test but it didnt work.
Would you mind helping me check if i could use v15 for 3G or 4G with public mobile?
Thanks,
chatrine
Thanks
@chatrine
Is your phone vivo V15?
Vivo V15 is not in the data base willmyphonework.net yet.....
3G bandsHSDPA 850 / 900 / 2100
4G bandsLTE band 1(2100), 3(1800), 5(850), 7(2600), 8(900), 38(2600), 40(2300), 41(2500)
https://www.gsmarena.com/vivo_v15-9614.php
 Public Mobile uses the following frequency bands:
  • 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
  • HSPA: 850 MHz, 1900 MHz (UMTS).
Not a prefect match.  Only one band with 3G and one band with 4G.  Not a phone expert, but you might have troubles with this phone with Public Mobile.
Maybe others can chime in....
geopublic
@chatrine wrote:
HI There,
Thanks,
@chatrine What is the make and model of your phone? To  make sure it's compatible with the PM data network Public Mobile has partnered with willmyphonework.net as the new compatibility checker.If you can’t find your make and/ or model, provide feedback directly here.
