Using the $20/$40 Long Distance Add On
dochok
Hello all,
If I have the $20/$40 LD add on, would that be sufficient to make calls from the US without getting one of the US roaming packages?
Thanks you!
But u asking calling from USA to usa or Canada
If u going usa and need service then you need u.s roaming add on
But if u just need u.s calling while in Canada then u can buy a 15 dollars add on which will give u 400 long distance which u can use for usa as well also those minutes roll over if u don't use em all
** I am not a Mod, please do not include any private info in a private message to me.**
dochok
Yes. I meant the 200/400 minute LD add ons. Sorry for the confusion.
Thanks for the clarification on the need for a US roaming add on.
cheers!
ShawnC13
@dochok, do you mean the 200 or 400 minute addon for $8/$15.  No you will not be able to call from the US.
200 minute addon is for Canada wide only minutes
400 minute addon is for Canada/International calling limited to 18 countries that are currently available
If you are going to the US you WILL need a US addon for any services that is required while there.
Samianauman
To call from u.s to Canada or u.s to u.s while in U.s
You need u.s roaming add on which is I believe 15 dollars for 10 days for text n talk and 20 dollar if u need 250mb hope that answer your question
