12-06-2024 04:20 PM
When I am in the USA do I just use my phone like I would in Canada? Or do I have to switch something. I’m looking at getting the 35$ can/us/mex plan with 50gb. This is all new to me and I’m a little hesitant. Not the most tech guy out there.
Service
12-06-2024 06:50 PM
Thanks, just checked my iPhone settings, the default for roaming was off, will need to turn on I guess.
12-06-2024 04:28 PM
@TheSterlinger wrote:@Blammo
Yes with that plan all you would need to do is turn on roaming and connect to AT&T, Verizon or T-Mobile.
There usually isn't a settting for just "roaming". The data roaming setting does need to be turned to use data, but that setting has no effect on voice and SMS services.
12-06-2024 04:26 PM
Right now I’m with Sasktel so my phone is roaming when I leave the province
12-06-2024 04:26 PM
hi @Blammo
change the network connection to Manual and choose one of the 3 networks. If one does not work, try the next one
12-06-2024 04:24 PM
Cannot or is that connect to AT&T and others ?
12-06-2024 04:23 PM - edited 12-06-2024 04:23 PM
@Blammo
12-06-2024 04:21 PM
@Blammo wrote:When I am in the USA do I just use my phone like I would in Canada? Or do I have to switch something. I’m looking at getting the 35$ can/us/mex plan with 50gb. This is all new to me and I’m a little hesitant. Not the most tech guy out there.
Yes. All of the feature included with your base $35 plan work the same there.
