02-20-2026 12:43 PM - edited 02-20-2026 12:44 PM
02-20-2026 12:48 PM - edited 02-20-2026 01:02 PM
yes, no roaming in Europe and hence you won't be able to receive 2FA text when you are there
All banks offers other ways to receive 2FA such as:
Check with your bank to see if you can change the 2FA the one that suit your need. Anything that allows access with local Wifi or local data will work
02-20-2026 12:47 PM
No you won't be able to receive 2fa through sms. You can connect to wi-fi only for internet but 2fa is through sms which you won't receive.
