Using card activation
Ina03
Hi
i had opened a line on Boxing Day and did not properly activated. SIM card has been picked up. Going to call virgin in 5 minutes. Could you please proceed the transfer?
thanks,
inha
HI @Ina03
you don't need to call Virgin for the transfer.
And do not call Virgin to cancel the account.  Account must be active for port to work
all you need to do is to login My Account, Profile and click Transfer Phone Number.  Then enter the phone number and account number
Then make sure Virgin sim card is in the phone.  Virgin will send you a text  and you need to reply Yes within 90 mins
Phil_Adelphus
@Ina03   As @Chalupa_Batman asked, why are you calling Virgin - hopefully not to cancel your account there before the number has been transferred, it needs to be still active.  For porting everything is done by the new provider and once the number has transferred the old provider account should be closed automatically.
Chalupa_Batman
Hello @Ina03
This is a self serve service. You do everything yourself here. If you do have problems signing up, you can reach a CS Agent via this link. However, you're not very clear here. You are calling Virgin for what?  Also, we are all customers like you, nobody from PM is here.
How to port number from “Blank” to Public Mobile
First, make sure your number can be ported by checking on this link
https://secure.koodomobile.com/checktransfereligibilityparrot/default.do
Or log in to your Public Mobile account
Then on your right side you’ll see this box. Click on Transfer Phone Number.
Then enter the number you want transfer and continue to next step
NOTE: Keep your old provider's SIM card inside the phone until you get the confirmation text. Say YES. But wait just a bit longer until you no longer see your old provider's name up top. Once it’s gone, try making a call to test. If you can not make a call using your old providers SIM, the transfer has gone through.
Created by Chalupa Batman
