02-01-2020 02:12 PM - edited 01-05-2022 10:30 AM
Hello all!
I don't know much about these things so this might be a silly question.
When on WIFI in Mexico, will I be able to send/receive texts and use the internet?
Thanks!
Service
02-03-2020 02:46 PM
As many have said wi-fi will give you internet access.
If you want to send text messages from your phone using your phone number you can install the Signal Messaging app. You can set Signal up to send text by Mobile data, or Wi-Fi data.
In Signal the setting is found in; Settings > Advanced > SMS and MMS. You will want to turn on "WiFi Calling" compatibility mode.
02-01-2020 07:40 PM
As long as you are not referring to Wi-Fi mistakenly as Data. Yes you can iMessage from an iPhone over wifi. But to text using a phone carrier....no you cannot text.
02-01-2020 07:29 PM
@amcgrath3 wrote:Hello all!
Thanks!
@amcgrath3 Feel free to use WIFI there to use internet, but texts won't be sent and received because PM has no international roaming addons or plans.
02-01-2020 04:44 PM
There are no PM roaming plans for Mexico, US only. Best to buy a local sim card while there and not worry about running out of usage days.
02-01-2020 04:05 PM
Thanks!
Wi-Fi doesn't have anything to do with your Public Mobile services. You could use Wi-Fi without a sim card in the phone. Standard text messages don't work over an internet connection.
02-01-2020 02:50 PM
PM does not have roaming add-on for Mexico. Therefore, you will not get text message as text mesages are delivered using the mobile voice channel. Wifi will not deliver PM text message to your phone.
Beside WhatsApp and TextNow mentioned earlier, you can also install Fongo app on your phone to call Canada and receive text messages. Fongo charges $3/m to send text messages.
02-01-2020 02:17 PM
Thanks!
No texts or calling unless you get a local SIM/plan in Mexico which are quite cheap there as PM doesn't have roaming plans outside of the US.
With Wifi you will be able to message using a messaging app like Whatsapp or others.
02-01-2020 02:15 PM - edited 02-01-2020 02:16 PM
No Public Mobile has no roaming add-on plans for Mexico. Wifi will work for Internet.
You can however look into the app called TEXTNOW.
You'll get a number in your area where you can call and text for free over wifi.. people can even leave you a voicemail if you're not online.
02-01-2020 02:15 PM - edited 02-01-2020 02:21 PM
No texts , yes to the internet. To send/ receive texts use an app such as whatsapp.
Thanks!
