Used Wrong Account Number When Porting Number
paulspicer
When I was porting my existing number on Rogers over to Public Mobile, I put in the wrong account number during the process. I found out because I can't connect to Public Mobile and got the text message:
4005000205: Public Mobile here: To complete your request to move to Public Mobile please go to Publicmobile.ca, click Contact us, and complete the SIM & Activation online form. Please ensure you provide the correct account number from your previous provider. Thanks.
I have activated the new Public Mobile SIM, and have called Rogers to get my account number, but I don't know how to attach the account number to the new SIM to get things going. I checked other posts and got the "Invalid SIM" error when trying to re-activate the SIM on the http://activate.publicmobile.ca form.
Help!
2 REPLIES 2
@paulspicer
Your port is stuck.  There is no activation online form to fill out.  You will need to contact moderator as described above.  It will likey take 1-2 days for things to get resolved.  Include in your message:  Roger's account number, account holder name and phone number.
In the meantime, you should be able to continue to use your Roger's SIM card.
GinYVR
You will have better luck contacting the Moderator_Team by clicking here; expect to hear from them via the envelope icon on the top right hand corner.. If it lights up with a number it indicates you have a message.
Put in as much pertinent information as possible.. they will send you a verification link.. answer that too asap.
