Usage History - Need help understanding
ute1978
In my usage history in the "Data Usage" column the usage is accompanied by another extra row with 0 MB for the exact same date and time. Does anybody know why?
9 REPLIES 9
srlawren
Hi @ute1978.  I think this may be a rounding issue.  I looked back through a half-dozen pages of my usage history, and I always get two Web entries together, one of about 1MB or so, and the other larger.  I think the usage is done in small time "buckets".  I don't know what the duration is, but pretend it's 5 minutes.  So think of the first one as data that you used just a few seconds before the next 5 minute window, and the amount was so small that it was rounded down to 0 in your history, and then the next 5 minutes contains the bulk of your data usage in that session.  Hopefully that makes some sense, but I really don't think it's anything to be worried about.
@Shazia_K, @Kalla_A, or @Mary_M, are you able to shed any additional light on how the data usage is presented in the history?
ute1978
@makkahn28 wrote:
Hi. The second screenshot I see is certainly not from the Add-On Data Usage, but from the Usage History.
But, all in all, at least we see how usage history works.
There are 3 screenshots in my post. But I guess we will leave it for now even though I still haven't gotten any answer to my initial question about the 0 MB.
ute1978
@makkahn28 wrote:
If you wanted to see your Data usage, where Orange covers Grey box, that's where to click
That's where I got the second screenshot (middle).
Correct icon.PNGHi. I know where you were looking at.
That is a mixture of both your Add-On Long-Distance, Unlim Mins, and Data stuff
ute1978
Hm, here are my screenshots to my plan and my add-ons. But why is my 1 GB an "add-on" if it is part of the plan?
Also in the last screenshot I marked the part of the usage history I meant before (for security reasons I deleted the originating and destination numbers).
Does your Data usage readout give you anything on your Rate Data usage?
Data usage.PNGDoes your Data usage Readout have this set-up?
ute1978
I have data. But no data add-on.
makkahn28
Hi. Does your Plna(s) have any Data, or No Data?
Also, though PM should word it properly, One is for Rate Data usage, while other would be for Add-On Data, which you must buy separately
Add-On Data never expires, but stays until you consume the last MB
