05-12-2022
08:27 AM
05-12-2022
08:35 AM
computergeek541
I added text and talk for 15 but should have added the 20 dollar talk, text and 250 mb of data.
can you switch me to that package?
thanks,
Darryl
05-12-2022 11:42 AM
If you explain this to a CSA they should be able to either refund to your balance so you can purchase the correct one or if you add the 5 in funds, manually make the change for you
05-12-2022 08:34 AM - edited 05-12-2022 08:35 AM
Generally, add-ons are final sale. Either way, by posting here, you're only communicating with other customers. To communicate with a customer support agent, you will need to open a ticket through https://widget.telus.tiia.ai/publicmobile/publicmobile.html.
