Us roaming
Kmcmahon
I put it on with  the two step process but it doesn't work when, I'm in the country I have a iPhone 4s
@Kmcmahon wrote:
Yeah I called the hotel and I got him to manually switch to AT&T
Well done! 👍👍
Kmcmahon
Have him do a manual search for networks and pick AT&T or T-Mobile. What plan did he pick?
Do you have an iPhone? If yes, send him a message via iCloud.
Kmcmahon
I looked yesterday and it was enabled but it was my dad's phone and he left to the US and I can't contact him
Luddite
Login to your account to be sure the correct add-on is there. Do any of the parts of the plan you purchased work?
nishufan
Hi @Kmcmahon
  Make sure you have correct APN and data roaming on. If the add-on not working. Contact our @CS_Agent to assist you. https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updated-Contacting-our-Community-Moder...
