03-29-2023
01:26 PM
03-29-2023
03:08 PM
computergeek541
I recently got back from a trip to the states and we were there for more than 15 days. I had bought the package with 3 GB of data and I renewed that package after the 15 days were up. But when I got to the Border I received a message that I had used 95 % Of my data even though I paid for the package
03-29-2023 02:18 PM
Yeah I encountered that when my plan ran out. Thanks for your help I’ve submitted a request and hopefully it’s all resolved soon
03-29-2023 01:55 PM - edited 03-29-2023 01:55 PM
when repurchasing the same US roaming add-on after the first one expires, public mobile has a dumb rule that it cannot be re-purchased until 24 hours after the first one expires.
If this did not meet your needs, let the customer support agents know, and I’m guessing they will offer some kind of a refund of the purchase price to your account.
Use the ticketing system for a faster response time. Click here and type Customer Support Agent, then select Contact Us, then select Other (or the topic that more closely matches your request). Click the result which states Click here to submit a ticket and follow the prompts, or,
Send a private message to the Customer Support Agent by clicking here You’ll need to be logged into your Community account for the link to work.
03-29-2023 01:47 PM
But my normal data doesn’t work in the states witch was why I was confused
03-29-2023 01:38 PM
@julia29wilkie so, that is a message for your usage on the regular data , not the roaming data
Login to My Account using Incognito mode and check the data usage to confirm how much you used
Let us know what you see
