Us Roaming
Miha_0707
I purchased us roaming add on and I'm in Usa and it doesn't work
DDM69
More details or a screenshot would be helpful.
@Miha_0707   which US roaming add-on you got?  just Talk? or Text ? or Data? or Combo?
getting Text and Data should be relatively easy, make sure your Roaming Data is enabled on your device
Try to connect manually to T-Mobile first.  If that does not work, try manually connect to AT&T
Also, where you are now? State and city?  Please note roaming does not work in Alaska
Roaming has been problematic especially after T-Mobile turned off the HSPA network.  If you force your phone to 2g on the T-Mobile network, do at least phone calls work?
